A new and impressive launch record for Intel's Skylake generation • HWzone
ComputersProcessorsMain
A new and impressive speed record for the Intel Skylake generation
Get to know the new speeding record that joins the never-ending list, this time for a CPU 4GHz to 7GHz is stable, with quite a few means on the way to the target
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
For any hardware product that comes into the market, whether it's a processor, , And even more (although on a much lower level of fire) a group of overkluckers from around the world is gathering, some of them known in the community and some of them anonymous, but the common denominator is the same: to be the one that takes the highest speed out of a specific hardware component.
This peak day belongs to Skylake processors, and if we become more specific, the strongest among them, i7 6700K that comes in 4 gigahertz operating frequency. The peak is 7,025.66 megahertz, and it belongs to Hong Kong-based Hong Kong-based chi koi lam. And he's not alone.
They do not take any measures
Do not hesitate in their efforts to squeeze a few more mega-runners into the frequency of the action
Immediately following are a pair of German overclockers bearing the nicknames Der8auer and Dancop, with both having some pockets in their pocket. The duo, which has even reached more than 7 gigahertz and failed, finished in second place with a "total" of 7,007.85MHz megahertz, just below that of Qi Koi Lam.
The proud Oberkeloker did not reject the means he used: Nitrogen at a temperature of 160 ° C for the ambitious work voltage of the Volt 4.032. With an 1,300 Watts power supply from Antec, 4 GHz efficient Trillent-Z 170 GHz chip and ZXNUMXM OC Formula Motherboard .
Peak frequency as photographed via CPU-Z
7 GHz frequency working at 4 Volt voltage can certainly seem too ambitious for regular overclockers, who usually settle for 4.6 GHz, up to 5 GHz for more advanced water coolers, from the rush process Getting more and more complicated. However, Qi Koi Lam's glory days are likely to be relatively short - after all, records were born to break.
Tags
תגובה אחת
Leave a Reply
Back to top button
Close
Close
