Why settle for fans with one-color illumination when models that offer a spectrum of colors that can be synchronized and programmed become more accessible and popular than ever before?
The appearance of the case is no less important today than the performance, it seems, and every hardware manufacturer adopts this situation in all seriousness and attention - when it seems that there are almost no components left that can not find built-in lighting in any configuration, which will testify to the economic investment behind the player.
Some consumers like a colorful mess where each purchase illuminates with its own method and hue at a given moment, while others have to see order, coordination and harmony between all the different elements for a complete presentation - and for the second category there are products such as the Prizm series from a company Antec, Which is designed to decorate the chassis and provide compatibility to almost all existing control and control applications on the market.
The Prizm fans can be found in stores with a common diameter of 120 millimeters and also with a diameter of 140 millimeters that is gaining significant momentum in modern cases - with both models consisting of seven blades and a rainbow with 18 colored LEDs with support for 16.8 million shades, and for programmed illumination applications. GIGABYTE, Asus, MSI and also ASRock. Unless you have a very exotic system, there should be no challenge here in incorporating the fans along with the other components.
The Prizm models are offered with a two-year warranty on their hydraulic rotation mechanism, which is designed to survive at least 40,000 hours of operation - and there is also a guarantee that their noise level will not exceed 32 decibels above the average room noise level at maximum speed.
Antec will offer the fans In some interesting combined cases - One with three 120mm Prizm fans, a pair of LED strips controlled for further decoration of the chassis and a dedicated control controller for their operation, the other with five 120mm Prizm fans and a control controller, and the third with a pair of large 140mm fans and a control controller. Quite surprisingly, the 120 millimeter Prizm ARGB fan will not be offered in its own package at all, although the 140 millimeter model will be available without extras.
The Prizm models are already available for purchase in a number of stores here in the country, when it seems that the prices may well be surprisingly good, also together for costs abroad - especially if you are looking for a solution Cooling Systemic air includes your PC.
