• Water Cooler - Khuler 920: The processor is cold, the pocket is empty. • HWzone
Computers
Cold water cooling - Khuler 920: The processor is cold, the pocket is empty
system Domestic water
Last year, manufacturers began dump In closed water cooling kits. The two most prominent manufacturers in the market were and still are Corsair and-Antec When Antek puts emphasis on cheaper systems and fits as wide a audience as possible. At the time of writing this review, Annette has two sets of water coolers offered to the market. The first - Khuler 620 Which is characterized by a fairly thin radiator designed for the middle market. You've got that cooling Already last year. In this critique we will focus on his great brother,Khuler 920 Which carries a thicker 3 radiator than we saw in the 620 model. ModelKhuler 920 Is a direct competitor of theH80 From home Corsair, With a similar radiator thickness.
Packaging and content - Khuler H2O 920
What's in the box:
  • Cooling theKhuler 920
  • Two fans with a diameter of 120 millimeters
  • Docking kit for seats and-AMD
  • A software CD for controlling the fans and light of the pump
  • User Manuals
How to install - LGA 1155
Installing water cooling kits is a pleasure for computer system builders, no less. That's that why? All you have to do first is insert the nuts into the posterior hole holes according to the type of bracket (there are three holes for three brackets Recent, not including LGA 2011), Attach the back of the motherboard to the holes and mount the cooling in front. Cooling is done by dying with a docking ring and dedicated screws. Put the block under the ring and tighten the screws until the pressure is pressed to the top, I recall that the block already smeared with a thermal paste.
That's it, that's all. The radiator can be installed in a device that is suitable for 120 millimeters in a pack. Not all of these devices may be suitable because there is the extra size of the radiator-attached tanks. The power will be connected by an 3 connector to the motherboard and the radiator will be powered by a connector USB Which has a dedicated cable.
Without going too far, let's go through the test system and test conditions and then the performance tests we have made for this cooling.
Our inspection system includes:
  • Processor: Core i7 2600K 3.4Ghz
  • Motherboard: Intel DP67BG
  • Graphics Card: Sapphire Ultimate HD7750 Passive
  • Power Supply: Thermaltake TR2 450W
Test modes:
effort - Status activated Prime95 Mode SmallFFT Which loads all processor cores and filaments to heat emission of 80 watts.
An exhilarating effort- Status activated Prime95 Mode SmallFFT Which loads all processor cores and filaments to heat emission of 140 watts. This processor is converted to a frequency of 4.5 GHz and an 1.42 volt voltage.
The first test is the 80 HWT test. In this test, we will examine the cooling under the CPUi7 2600K When it runs in default settings on full effort. The displayed value is the difference in temperature between the processor temperature and room temperature (delta).
1 2 3Next page
Tags
6 תגובות
  1. Rasa240
    It costs a lot more, a bit problematic for me to estimate the price nowadays, but I'm on this kit with another 120 radiator, and a graphics card heat sink I got to almost NIS 1200. Not cheap.
  2. I bought the 920 and ..
    My 2600K is energized on 4.7Ghz with 1.3 processor power and 38 temperatures at idel and full prime95 effort comes to 58 degrees with a room air conditioner on 25 degrees.
Leave a Reply
Back to top button
Close
Close
