• Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Recommended computers
  • Trade-Zone
  • Coupons and promotions
HWzone
  • Featured articles
  • Reviews
  • Guides
  • Technical Support
No results
View all results
HWzone
Main Computers
Corsair Crystal 280X case under review: Compact and elegant RGB
By Lior Matityahu
20/11/2018
We took a critique of the new creation of Corsair - mATX case that combines modern features such as compatibility for water cooling, tempered glass window and of course a lot of RGB
Corsair has recently become a household name in the aesthetics of PCs. The company has equipment such as keyboards, mice, cases, power supplies, water coolers, headphones and more - all of which have a fairly clear and uniform design line. This is to strengthen the brand's familiarity between the various computer users and create an environment in which as many of its parts as possible come from the same manufacturer. Corsair And enlightenment RGB Have already become best friends.
In this review we had the opportunity to experiment with a special case of the company, one that includes its various features but without the use of huge dimensions - this time it is the turn of midsize computers with a case in the configuration of mATX, or Micro ATX. This configuration allows motherboards with 4 expansion slots or less to be installed.
God-Crystal 280X Belong to the family of Crystal Cases Corsair, Which is characterized mainly by the use of sealed glass as doors and as additional elements. The most popular packages in this series sold in Israel are 460X and 570X. The 280X package comes in a price tag of 170 USD, or 725 in Israel.
The package comes in a large, well-padded package. Elastic packing material is used in a respectable quantity.
The crystal 280X may seem high, but in fact its height is relatively modest and stands at only 40 centimeters. As noted, tables are supported if the mATX and mITX standards have 1-4 slots to expand. This chassis uses the 2 method for partitions to install and organize the hardware. One partition is designed for the motherboard area while the other, the rear, is designed to provide power and storage.
The front and top of the chassis have two outputs USB 3.0, headphones and microphone, as well as power and fire buttons. This package does not exist USB Type-C is unfortunately front-end.
The back of the case contains a removable air filter with magnets for use with the power supply and other components such as the volume that can be ventilated by docking a fan.
The door on the side of the case and the glass cover on the roof come with this closing mechanism. I think the screws are too long but at least we can tell that the glass is properly secured to the case.
The chassis roof can accommodate two size 120 fans and one with light bulbs RGB On the roof. The glass cover sits about one centimeter above the ventilator area and leaves a gap where the hot air can come out. It is important to note that there is another fan in the front of the chassis.
This is what the partition is for the motherboard and the components installed on it. There is a generous use of guys who serve light and successful wiring, and also use rubber to hide cables. There is room for installing 4 120 more fans as there is room for two more at the bottom of the case.
The second partition designed for the power supply contains rubber legs that allow for its installation and absorption of vibrations from its fan. There are also two controllers that come with the case. These controllers are connected by a USB cable to the 2.0 on the motherboard, and they control the fan lights using the iCUE software Corsair. There is also control over the rotation speed.
When it comes to means storage, There are three trays 2.5 INCH and two inch 3.5 trays that come with an adjustment to the 2.5 INCH so I would describe the support for the storage in this highly worthy package. You can completely disconnect the drive devices and remove them from the chassis.
Time to start assembly. This part is entered by an 850W provider with a standard length of 16.5 centimeters. There is plenty of room for power books in Crystal 280X and many 1200W power supplies will enter here without a problem.
The motherboard used is the Asrox H370M Pro4, along with a processor Core i5 8400. The memory is the ADATA D80 2X8GB with RGB LEDs. Also, the video card that was assembled is the Palit Geforce GTX 1080 Jetstream, one of the largest video cards in the environment. Cooling The processor is the NH-L12 Noctua.
This graphics card that comes along 31 inches still has room to grow. The cables that connect to the graphics card do not have much space in this situation, and they have to be relatively flexible so that the door can be conveniently closed to them if they use an ultra wide screen card.
let there be light! My love for packaging and white hardware is not for nothing. Neutral and light color is a great way to shed and scatter lighting.
Of course, we conducted a number of tests for this system to see that the package meets the hardware requirements and turns the heat efficiently. Examine the case with a complex side door and then remove it to see how the natural air circulation contributes to proper cooling.
The test conditions are: room temperature of 21 ° C, natural ambient noise of 28dbA and measurement at a distance of 30 centimeters from the case.
When open door mode:
The video card During an effort at 73 ° C, the processor was at 67 ° C. The ambient noise was 32.2dbA.
When closed door mode:
The video card During an effort at 74 ° C, the processor was at 65 ° C. The ambient noise was 30.6dbA
There has been a fairly decent improvement in the noise level that the computer produces, and it seems that cooling also does its job well. The computer becomes quieter when effortlessly when the door is closed than it is open and it is great.
Summary
It's nice to see some love for the medium-sized computer world. Not everyone wants huge monsters on the table and there is an existing niche of mATX and mITX users who want a solution that is suitable for these motherboards.
This chassis, especially in white, is a new spirit in the Mini Tower enclosures and its construction quality is quite good. With the use of large physical force at many points we did not find any weak points. Each frame is made of metal and a very respectable quantity. I think it's a very respectable addition to the series Enclosures It is popular and good to know that there is also a smaller.
The price of the package is NIS 725, which is not cheap at all in the packaging world. I think my main criticism of this pack is mainly the fans themselves. I would be happy to see a slightly more aesthetic and uniform appearance regarding the number of fans and their installation.
I think that at this price level in order to make the case more cost-effective,Corsair Consider installing 4 fans and sanctifying the purity of theRGB And airflow. I think this is a bonus that many users will appreciate.
Besides, I think it's a fantastic mATX package. Good fan mounting options, character support and excellent hardware type, also have compatibility for advanced water cooling.
Recommended - computer case Corsair Crystal 280X RGB
Tags: CorsairRGB
Related promotions:
On the same subject news
The processor that will return the crown of performance in gaming to Intel? Meet the Core i9-11900K
Computers
12/01/2021
Intel promises that those who want to take their games to the maximum that they should stay in its camp - and wait a little longer for the next hot thing to land
קרא עוד
NVIDIA Announces GeForce RTX 3060 - With Surprisingly Large Memory Capacity for Everyone
Computers
12/01/2021
The graphics core maker also misses out on those looking for cheaper graphics cards than has been offered so far and unveils the GeForce RTX 3060, which has 12GB of GDDR6 memory
קרא עוד
Show more
  • Most popular
  • The most talked about
  • the newest
End of year craze at Epic Games Store: Free game every day until 2021
23/12/2020
Historical Opportunities: Amazon's laptop prices are falling along with the dollar
13/12/2020
Hot Deals With Low Dollars: The Latest Deals On Amazon
29/12/2020
Ending a year with optimism with Ubisoft: Six days of free games
23/12/2020
Low Dollar Makes Great Prices: Deals for SSDs at Amazon Store
13/12/2020
The free Epic Games Store parade continues
26/12/2020
Great success even before the first day: The numbers of Cyberpunk 2077 give important hope for the future
Success or actually disgrace for generations? The rush around Cyberpunk 2077 refuses to go away
Step forward, step back? Intel's Rocket Lake models are leaked with increased detail up to just eight cores
The following RTXs are approaching: NVIDIA is hosting a media event early next month
A 70 percent jump in the number of processing units? The next generation of NVIDIA stars in the rumors
More memory, less money - a GeForce RTX 3060 card from Asus leaks before the announcement
12/01/2021
12/01/2021
The weights speak for themselves: LG's Gram mobile family is expanding
12/01/2021
Get to know Lenovo's new computers - with a choice between Intel, Qualcomm and AMD
12/01/2021
Intel at CES 2021: Tiger Lake processors strengthened now, doubling the amount of cores soon
12/01/2021
Coming soon: Xiaomi Mi 11 also for 5G challengers
11/01/2021
HWzone is the oldest computer and technology site in Israel, which has been used for many years as a home for lovers of technology, computers and gadgets.
Wise consumers who like to be on the digital front - helping computers understand people since 2001.
  • about the site
  • Contact Us
  • Advertise with us
  • Terms of Use and Privacy Policy
No results
View all results
  • Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Trade-Zone
sponsored
