Fast for all Skylike processors, even without open product • HWzone
ComputersProcessorsFeatured articles
Fast for all Skylik processors, even without an open product
A great line for enthusiasts The extra free performance: the ability to accelerate base frequency in new generation processors It finally gets into operation on some motherboards
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
One of the most promising features of Generation of the sixth Core processors של He finally got into high gear. Do you add a frequency of tens of percent to "discounted" processors that do not offer an open product? Soon it will not be just a dream anymore.
Confused? Here is the explanation: Modern processors have a low base frequency created for the processor, and it is synced correctly to all other hardware components in the system (so as not to create errors and compatibility issues). So if there is a low base frequency, how does the processor reach thousands of gigabytes? With the help of the Patriarchs. The processor multiplies the base signal, reaching its real high frequencies. For example, if the processor has a base frequency of 100 MHz, the processor will multiply it by 21 once to reach a frequency of 2.1 GHz.
The ability to multiply the base frequency enables the processor to move between the frequencies quickly and efficiently according to the demand of the processing power at any given moment, without leaving synchronization with the rest of the system elements (video card, and so').
A comeback for haste?
In recent generations of processors, Intel has provided the ability to change the same base frequency of the processor only at high jumps (from 100MHz in standard mode to 125MHz), which in most cases causes components, especially PCI-Express on-board, to go out of balance and stop working Intended - so that the speed for processors whose multiplication is locked and does not exceed the frequencies set by each model Itself was unreasonable, even though in practice it existed.
In the current Skylake generation Intel has decided to move towards consumers and provide the other system components with their own base clock, so the processor base frequency can be changed over a wide range, and with moderate and even lesser MHz jumps - which opens up the very interesting option to add about 10 or 20 MHz To the processor base frequency, and get a practical improvement of hundreds of megahertz and even gigabytes for their work speeds. As we can see now, this interesting capability can actually be made available not only to the expensive open-frequency multiplier K processors, but also to other cheaper models whose frequency multiplier is locked up.
ibck
This soon-to-be-known but not-so-soon-to-be-launched option starts to crust skin - and also provides the goods with the potential to improve tens of percent frequency based on standard air coolers, As already demonstrated on the site overclocking.guide Based on rugged beta versions that support the ability for Z170-based motherboards.
ibck5 ibck4
A huge improvement potential, at least in some models, which reminds us of the glory days of the processors - Discounted 2 Duo
The first manufacturer to undertake the promised speeding capabilities is Asrock, Which now offers BIOS updates For all its motherboards that are based on the Z170 chipset - this is the place to note that an update to the motherboard firmware should be done carefully, responsibly, and after reading the appropriate instructions. If you are unsure or worried about something - our forum system is always here to help.
ibck3
Respect for the first manufacturer to provide one of the features that may make the upgrade to the next generation, Much recommended, much more
We believe and hope that after the current opening of Similar firmware updates will come from other manufacturers in the motherboard market, allowing all Z170 board owners to get the best out of their processors - and who knows, based on previous generations, we might see the speed capability coming to cheaper motherboards based on the H170 and BXNUM chipsets as well .
Motherboards that support basal frequency acceleration after BIOS update are appropriate
Motherboards that support basal frequency acceleration after updating appropriate
This is probably also the place to note that too It's a business that needs to be done with forethought. The possibility of permanent damage to a modern processor with Is seemingly very small, but performing it in a non-moderate way may result in loops of non-response that will require the zero- Physically to return it to its default state. Beyond that, there is no need to worry too much - this is your opportunity to add a few hundred MHz to your processor's working frequencies, simply and easily.
Those who are not afraid to use extreme curbs can achieve even greater results, and in a way that returns part of the pepper that existed in this area during the previous decade
For any question, problem and updates - Remember that our forums are here for you.
Tags
3 תגובות
  1. Cool, fast as in the good old days of the C2D!
    And it really works and gives great results, at least according to the pictures ...
Leave a Reply
Back to top button
Close
Close
