Package contents
It is important to note the size of the package, the size of which will not embarrass any other system, and is certainly the size of the other systems that are priced at the upper end of the market.
What did we get?
- Pair speakers Stylists
- Subwoofer
- RCA cable for RCA, miniPL cable for miniPL, cable for connecting speakers (each 1.8 meter in length) and power cable
- Training paperwork
- Wired remote control with cable length 1.8 meter
A closer look
First we look at the stereo speakers. As you can see, these include a four-pin connection similar to what exists in power supplies to a computer. You can see that they are encoded in colors (red and white) to make sure that you place the speakers as -Corsair Intended, when the tweeters are placed on the right side of the instant element so that the stage is playing on its right sides. For those who accidentally connected the speakers in reverse, do not panic: no damage will be done. The only scenario that can cause damage is if the connection is misaligned - but the connection includes a pin that locks it in, so it needs to be extra bulky to connect it upside down.
The fact that the connection consists of four conductors (instead of two on most speakers) is due to the fact that each element has its own amplifier, so the signal must be transmitted for each element separately (two conductors each). For those of you who want to extend the cables beyond the original length, this can be done easily by purchasing appropriate extension cords. For those who want to extend the cable's cable, this can be done using a standard SVGA cable.
At the back of the subwoofer there is a standard power connection (although the cable supplied with the system is not grounded). In addition, there are a pair of input connections: RCA connection and mini-PL connection (3.5 mm). There are also connections for the solitaire speaker cables and a connection to the wired remote.
A connection that is definitely lacking in the system is a digital connection, whether optical or coaxial. For a system that uses a digital filter with digital amplifiers, expect a suitable connection that would reduce the requirements for a quality sound card, and improve the quality. According to Corsair, They chose not to add such a connection because there is no need to decode DTS or DD in a system of 2.1 channels (decoders,Corsair Of money). In our opinion digital signal support is a big advantage in such a system.
Page 2 from 5
