No external power connections: First GeForce GTX 1650 cards floating in the network • HWzone
Computersgraphic cardsFeatured articles
No external power connections: First GeForce GTX 1650 cards floating on the network
Shortly before the expected official announcement, we are verifying that most new interim cards are from Will be particularly economical and will not require more than 75 watts of power to operate
The GeForce GTX 1660 and GeForce GTX 1660 Ti cards have proven that the Turing architecture can be not only very affordable in cost-benefit relationships - but also more efficient than any other available on the market, even at popular HD and QHD resolutions. We are now approaching the unveiling of the modest GeForce GTX 1650, which may take this trend a step further and break even more highs for .
We know that the next green camp ticket will offer us a new type of processing core that will be smaller than any we have ever met within the family - The TU117 core that may only contain 1,024 CUDA units in its full configuration, and even less so in the GTX 1650 models that come to the stores. However, the latest production process at 12 nm should give its signals with fairly high operating frequencies, without breaking the power consumption limits dictated by the standard. 3.0.
Miniature Dimensions Card With No External Power Connections - Best For Extremely Compact Computer Systems?
Image source: videocardz.com
The first GTX 1650 models from Zotac and Palit have been leaked to the net through videocardz.com, with a modest number of video outputs (1 HDMI, 1 DisplayPort and 1 DVI-D in 1 and DisplayPort and DVI-D only) Which include a single fan and compact dimensions that should fit any microATX or mini-ITX enclosure in the environment.
The various models do not include external connections to the power supply, despite the fact that the chassis boast rushed frequencies from the factory - which means they will operate in any mode with 75 watts of power or less, with the potential to be extremely cool and quiet as a bonus, depending on the cooling solution's effectiveness.
The Siamese twins from home And from the Gainward brand it owns - with a design that looks even more budget and basic than Zotac's
As for the working conditions themselves - the Palit models are designed to operate at 1,665MHz speed as the base and reach up to 1,725MHz in Turbo Boost mode - nearly 30 percent above the base conditions of the GTX 1050 Ti, which together with a larger amount of processing cores should significantly boost the forward performance while maintaining a very similar power envelope to the old popular model.
A leak from the mobile market declared an addition Of about 25 percent for the GTX 1650 compared to the GTX 1050 Ti, but according to the dry data we currently have, it is possible that the improvement in the stationary market will be even greater, could also reach 40 percent - all under similar power consumption, as stated.
The main question that remains for us now is the price of the new models - 180 dollars or maybe less? With the uncomplicated competition that is also expected from the Radeon RX 580's old liquid As well as the GeForce GTX 1660 featuring the same benefits With a significantly larger amount of CUDA cores operating at no cost of 220 dollars. We hope to receive all the missing details soon.
Tags
2 תגובות
  1. And this is even before the transition to 7NM that will occur in the coming year.
    In the next generation we can get 1660TI / 1070 performance without additional power connection.
    1. In the meantime, nvidia has no reason to spend 7nm I'm just waiting for amd to issue something 7nm and then nvidia will have to act
      Although nvidia takes the heavy gaming market but in home use amd takes and big and that is actually the majority of the market
      Nvidia has no concerns that it has the big and expensive markets with the quadro and titan series
      All that is needed is that amd will come with one powerful card that will make nvidia work
Leave a Reply
Back to top button
Close
Close
