• Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Recommended computers
  • Trade-Zone
  • Coupons and promotions
HWzone
  • Featured articles
  • Reviews
  • Guides
  • Technical Support
No results
View all results
HWzone
Main Computers
Plextor M6e Audit: The SSD that breaks the limitations of the SATA3
By
04/07/2015
FlexStor's new M6e drives up for review - let's find out what exactly the era of thePCI-Express Of the SSD drives
In recent months, the personal computer market has made a big leap in terms of interfaces and storage compliance. First, the Z97 chipset was launched Intel And more recently the X99 in the extras. The new chip sets also have interfaces storage SATA Express and M.2. The purpose of these interfaces is to provide the speed potential that does not exist in the standard SATA3 we have known over the last four years.
The M.2 interface has become particularly popular with new motherboards today, more than SATA Express due to its ease of implementation on motherboards. This standard is also present on computers Mobile Many today. This interface contains the speed potential that has actually been available to us for many years. It is important to clarify that there are two types of internal connections in M.2. One is SATA and the other is SATA PCI-Express. Drives connected to SATA will receive traffic through the SATA port controller and the chipset system, while a SATA connection PCI-Express Provides traffic that usually arrives through thePCI-Express In the chipset. There are several motherboards where the indicator is made directly to the controller.PCI-Express In the processor instead of the chipset to achieve higher speed.
M.2 SATA and type PCI-Express Usually exist in one connection. Thanks to the physical similarity between the two types, most of the M.2 interfaces you find today are compatible with both the M.2 SATA drives and the M.2 PCI-Express.
A drive that uses the M.2 interface is currently in the audit PCI-Express But does not connect directly to the board but comes with a standard-PCI-Express himself.
Plextor_M6e_01
ID - Plextor M6e 256GB
  • Length: 18 inches
  • thickness: A single slot on the motherboard
  • Controller Memory Chips: Marvell 88SS9183 dual-core
  • Memory chips: Made Toshiba In the process 19 nanometers
  • interface: PCI-Express 2.0 X2
  • warranty period: five years
The M6e is a unique drive. It is difficult to define its competitors,SSD Prefers to create drives in the M.2 standard and save the possibility of changing the interface for third-party companies. It costs $ 270 in the United States and NIS 1600 in Israel.
Packaging and content
IMG_3850 IMG_3851
IMG_3852
The drive comes with a user training page, an installation screw and a warranty booklet. Unfortunately there is no software disk of any kind that includes special tools.
An external look
IMG_3853
In the simplest way, the M6e of Flextor is an M.2 drive mounted on an interface adapter PCI-Express. It appears that this product was manufactured by Falcastor mainly for those who do not have a computer that includes the M.2 interface,PCI-Express Is very common and has existed for many years in the market.
IMG_3854
Unfortunately, even when you upgrade your computer to the one with the M.2 interface, Falcastor will not want you to use the drive directly in this interface. She pasted a warranty sticker between the drive and the printed board of the adapter toPCI-Express, So removing the drive from the chassis will violate the expensive five-year warranty that this drive carries. The interface to which the vehicle connects to the motherboard with which it is connected PCI-Express In the 2.0 version and the bandwidth of X2. This interface provides maximum data traffic of 1000 megabytes per second.
IMG_3855
The front of the card includes three indicator lights. These lights are on when the drive is on and one is also used to monitor charging action similar to the front light bulb in many computer cases.
IMG_3856
IMG_3857
The drive itself contains the components you will find in any advanced Pasteur drive. This drive uses eight advanced chipset Toshiba Produced in the new process of 19 nanometers. This gives them not only high volume but also extremely low power consumption. Each of these eight chips can contain 32 gigabytes of information.
The memory controller is Marvell's 88SS9183. This is a dual-core memory controller that has been pre-designed to work with drives in the PCI-Express interface, either physically or via the M.2 jumper. This series of Marvell PLCs is the biggest competitor to companies like Samsung in the fast-paced storage performance market. The controller uses 512 megabytes of RAM DDR3.
Although Pasteur eliminates the warranty if you unplug the drive from the card slot, it sells the M6e only in M.2 only, which makes me wonder even more about what it means.
After the technical part, it's time to see what the M6e is worth. It is important to remember that even if the drive is connected through PCI-Express In the newer 3.0 version, it will only run on the 2.0 standard in the interface, so it does not matter.
Page 1 from 3
123הבא
Tags: IntelSamsungMicronSSDPlextorCorsairOCZASUSstorageSanDisk
Related promotions:
On the same subject news
Lost in battle, but not in war? NVIDIA may launch "mining-protected" versions for all of its video cards
Computers
21/04/2021
The first attempt to slow down cryptocurrency mining capabilities with the RTX 3060 models is a pitiful failure - but it seems that the green chip developer has not yet said its last word on the subject, and plans to return to war with a whole line of revised versions
קרא עוד
More selection and more power: More details on the next wave of Tiger Lake processors
Computers
20/04/2021
The 11th Core generation has not yet finished its historic role in the mobile market - with senior models of six and eight cores appearing ready to launch at any moment and the possibility of a quick refresh for the newly established category
קרא עוד
Show more
there is Connect to the system To post a comment.
  • Most popular
  • The most talked about
  • the newest
Sony in Extraordinary Generosity: Ten free PlayStation games for everyone
27/03/2021
The fastest for gaming? Core i9 11900K and Core i5 11600K processors in comprehensive review
30/03/2021
Core i7 11700K performance in review: Is Intel's 11th generation successful in the task?
31/03/2021
Familiarity with WD Red Plus - a hard drive that ensures a modern combination of speed and reliability
09/04/2021
Rain of titles: Sony and Microsoft's free games for March 2021
06/03/2021
Steam Festival: Thousands of games at big discounts
28/03/2021
Entering top gear - Intel announces huge investments and a particularly ambitious production strategy
Israel is waiting for it: the Mi 11 Ultra is the creative splendor of Xiaomi
Silicone Art: First details about the Ryzen 7000 generation
Another star worth waiting for? New details about the Xiaomi Mi 11 Lite 5G
The foundations continue to crumble: Blizzard loses a VP and an important key figure
21/04/2021
Worth to be friends with Sony: The game Horizon: Zero Dawn is available for free to everyone
21/04/2021
21/04/2021
20/04/2021
Popular gaming in 2021: GIGABYTE G7 laptop with RTX 3060 in review
18/04/2021
Two that are a rare breed: Xperia 1 III and Xperia 5 III are another reminder that Sony loves to be special
17/04/2021
HWzone is the oldest computer and technology site in Israel, which has been used for many years as a home for lovers of technology, computers and gadgets.
Wise consumers who like to be on the digital front - helping computers understand people since 2001.
  • about the site
  • Contact Us
  • Advertise with us
  • Terms of Use and Privacy Policy
No results
View all results
  • Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Trade-Zone
