First in line: ASRock Radeon RX 5700 XT Challenger • HWzone
Computersgraphic cards
Meet the first Navi models that will not be based on the basic cooling design - and will try to bounce forward performance through improved engineering
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Similar to MSI, It seems that the Taiwan company ASRock did not really succeed or wanted to hold back - and decided to officially announce the Radeon RX 5700 and Radeon RX 5700 XT models Designing and engineering its own adapted now, a month before making their actual availability in stores.
The company's first series To the Navi era You will get the brand name Challenger Challenger, and will offer Double fans with a diameter of 10 one centimeter, along with a body Aluminum 4 tubes are made of 8 8 thick heat conduction tubes each, as well as a back-formed metal plate (in shades of black, white and yellow) to provide additional mechanical rigidity to the product and help with uniform heat dissipation.
Brand new alongside Phantom , Or in its place? We'll probably soon find out
The 28.1PIN will provide a pair of 8PIN connections to power the extra power supply from their PCI Express 4.0 × 16, offering three DisplayPort ports 1.4, and a single HDMI 2.0b port - and increase the base frequencies and Boost frequencies in 40MHz to 50MHz relative to the reference models from. It should be noted that there is no growth in the upper game frequency of the models, which is also available in reference models, apparently not to exceed the original thermal envelopes - but it is quite possible that the improved cooling will allow the Challenger models to operate longer at maximum frequencies so that the actual performance will be upgraded this.
The RX 5700 and the RX 5700 XT will offer the same exterior appearance in the Challenger series, and will need two slots in your package
Recommended prices of tickets are not yet known to us, but it is quite reasonable to assume that Will choose to launch more of its own dedicated models later on, perhaps with more massive cooling and an enlarged power envelope that will also accelerate the frequency God- Built-in and maximum core frequencies to which you can reach. We will continue to follow and update you!
Tags
Back to top button
Close
