Surprise: The GeForce GTX 1650 will be cheaper than we thought • HWzone
Computersgraphic cards
Initial rumors predicted a recommended price tag of 180 dollars for the video card from the middle market - but we now have its full technical specifications, and a statement that the price will start from 150 dollars only
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Mark the 23 in April: In the middle of next week, the GeForce GTX 1650 is scheduled for landing, which will probably be the cheapest Turing model in the current generation of - Almost as cheap as the GTX 1050 Ti it is designed for network.
At videocardz.com Provide us Now the full base data of the intriguing budget video card, based on the TU117-300 core with 896 active CUDA units and 4GB of GDDR5 memory in the 128 bit interface and 8,000MHz effective speed (giving a total bandwidth of 128GBps). These graphics card cores will offer an 1,485MHz operating frequency and maximum 1,665MHz turbo frequency, When we already know that there will be models flying straight from the factory In frequency Basic of more than 1,600MHz - a definite significant addition that should be expressed in double digits in practical performance.
The specification is very similar to what the leaks predicted - but the price is more lucrative
Image source: videocardz.com
The card will benefit from a power envelope of 75 watts and will not need external power connections, although at least some of the more advanced versions will add a single 6PIN connection to provide potential Maximum without encountering a bottleneck of power consumption - and the biggest surprise is the promise of a starting 150 dollar recommended price, which is only $ 10 higher than the recommended launch price of the GeForce GTX 1050 Ti two and a half years ago. According to the data on paper, the GTX 1650 is expected to provide improvement Of about 35 percent at a minimum - so much more lucrative than his old counterpart.
The first models of the GTX 1650 appeared in the French version of the Earlier than expected - when prices that include the European VAT increment seem to match our latest information
$ 70 Pricing Gap Between the Expected GTX 1650 Base Versions and the GeForce GTX 1660 Base Versions leave a proper range for incorporating another intermediate model, it seems - the GeForce GTX 1650 Ti that might be based on TU117-400 graphics with a greater number of processing units and improved operating frequencies. when will it happen? We will focus in the meantime on the launch before we begin to try and predict the next stage.
Tags
Back to top button
Close
Close
