Today we will look at the new CoolerMaster plug-in to their high-power power supply line. A few months ago, CoolerMaster launched the new Silent Pro M2 Series, a series of high-power modular power supplies.
Key features
Fix 80 + Silver - Ensures that when loading 20, 50 or 100 percent of the declared power, the power efficiency will be at least 85 percent. What it means? The efficiency of the power supply is the force coming out of it parts of the force entering it. The rest of the power is converted to heat. The higher the efficiency, the less power the actual power supply consumes from the wall socket.
A.PFC technology - Technology This independently converts the voltage entering the power supply, whether it is 110 volt or 230 volts. Technology This enables much better voltage stabilization compared to power supplies that include a manual switch of switching between incoming voltages.
Modularity - This feature allows disconnection or connection of desired cables to a power supply according to the user's requirement so that there will be no unnecessary cables in the enclosure which waste space and impair airflow.
Supplier Statement
12 Volt rails - Two rails, one of which at a power of 55 amps supplies power to the welded cables and one with a power of 70 amps provides power to the removable cables. The total declared power for use at 12 volts is 1440 watts.
3.3 and 5 Volts - One rail that provides 30 amps (150 watts) for the use of motherboard components mainly as Memories And colds.
In conclusion
The ambitious hardware users know very well what they need to severity their extremes, whether they are components Super Computer Or promotions Overclocking Under extreme refrigerations. In terms of use, the power supply Silent Pro M2 1500W contains all the necessary features - high efficiency, extra long cables, many connections and not bad sleeping.
The obvious drawbacks of this power supply will be a disadvantage, such as welded cables, which are not small at all. Considering the manner in which this power supply is used, this power supply is not intended for systems with few components. Another drawback is the slippage of the welded cables. We would love to see welded cables that get the same slippage as the cables. Using another silling destroys the same uniform appearance many system builders want to create. The third disadvantage is of course the price. The difference in price between the power supply of the 1200-1250 and the 1500 watts is very large and does not match the difference between the power supply. This is typical in every area of the hardware market, but the difference here is significantly greater.
Another notable disadvantage is the power cord. We received power supply with a European cable that does not include grounding. Anyone who buys such a supplier in Israel will have to find a suitable cable that includes a grounded connection.
The launch price of this power supply is $ 399, slightly more than other power supplies at 1500 watts, but this price will not be a problem for hardware enthusiasts who really need such high power.
