Core i3 7350K Review: Open Product and Overclocking as You Have not Seen • HWzone
ComputersProcessorsReviewsFeatured articles
Core i3 7350K Review: Open and Overclocking as you have not seen before
Intro
When we thought it would never happen again, Surprising with processor i3 that contains the ability to perform frequency speeds - and now we give you the critique that will reveal all its capabilities and even guide you on how to perform Your own
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Since the release of Sandy Bridge and the family i3, i5 and i7 of the second generation, overclocking was reserved for certain processors only. Unlike previous generations, new conditions were created for implementation The processor and those who wanted to do it had to be absolutely committed to it.
In what I usually call the "overclocking triangle," for the purpose of speeding up a user processor Supports, Supports CPU and Advanced CPU Cooling. This reduces the number of users performing In a noticeable way. The option was offered to everyone when buying a new computer, but many simply refused because of the economic sacrifice they would have to do just so that they might touch the subject in the future.
In addition to this, Overclocking was mostly reserved for expensive processors in every series. 2600K and 2500K in the Sandy Bridge generation brought capabilities , And so each i5 and i7 series in each generation that came after that contained a K processor that could be executed . The K indicates that the processor doubles are open to changes and so, even though the base frequency was and remains locked on the 100 MHz, the frequency of this frequency can be raised on supporting motherboards.
Three years ago was a tribute of The "Pentium" brand that accompanied it 20 a year ago, and released a dual processor Just had an open product, but it was not very popular due to the need to use an advanced motherboard which in most cases exceeded the processor itself.
This time she enters for the first time Processor i3 under its overclocking processors.
Core i3 7350K - No more worrying about sales damage i5
Perhaps one of the main reasons we have not seen Core i3 processors with open product is the concern that simpler Core i5 processors will simply be considered useless when a cheaper processor can compare performance. The new Kaby Lake generation and 7000 series has decided Since it is possible to do so, i5 The "simple" 7400 already comes at the frequency of 3.0 GHz, unlike i5 6400 which reached a relatively low frequency of 2.7 GHz.
Core i3 7350K - Specs
  • chassis: LGA1151
  • Cores: 2 cores and HyperThreading function for two additional logical ones
  • Frequency of operation: 4.2 GHz
  • cached memory: 4 megabytes of third level
  • Manufacturing process: 14 nanometer
  • Brown Shell: 60 watts
  • Overclocking: An open product can be made on boards with Z170 and Z270 chip sets
  • Built-in graphical core: HD 630
  • Recommended retail price: Starting from ILS 800
For some of the technical features of Kaby Lake Here binds the review of Core i7 7700K. There you can read about what's new in this generation of For the LGA1151 chassis. In this review, we will focus mainly on how fast the i3 7350K is, especially in overclocking, and we can also focus on the way to do the overclocking.
It's time to go straight to the performance tests. The test system has not changed and remains similar to the one we used in the audit i7 7700K
Test system for performance tests
  • LGA1151 Chassis Motherboard: Model Z170 Extreme6
  • Motherboard for Extreme Bracket: Gigabyte X99- G1 WiFi
  • CPU Cooling: NH-D15
  • Memory: G.Skill Ripjaws Z 4X4GB 2666Mhz
  • Power Supply: HX1050 1050W
  • Graphics Card: GTX 780 Ti MATRIX 3GB
  • hard drive: 830 128GB
  • screen: BenQ XL2430T 1080P 144Hz
  • Operating System: 10 Pro
Additional processors being tested
Processor performance in games
The world of computer games today is bigger and more varied than ever before. Like the amount of types, graphics engines, and design styles, so does the performance of the games on different hardware today.
We took three prominent recent games known for heavy and proper use of modern hardware, especially in efficient use of cores . These games are V, Witcher 3 and The Divisionn, three games that are very popular these days.
Our performance tests on these three titles show us a very clear picture of 7350K. This is after all a processor that has 2 physical cores and two logical ones, which is completely expressed in the number of frames average per second, and especially in the minimum. A low minimum is due to the processor's inability to stop surprises with a high load for a short time, which means that a processor with more cores can do so clearly.
This leads to a game experience that can be problematic in fairly heavy titles like these three. By the way, the reason we chose them to be the recent CPU reviews. While, V The picture is quite good, and there is no need to be afraid to choose i3 7350K as a processor for the gaming system, the Witcher 3 indicated a completely different picture. Complex environments with many elements need a fleshy processor that can withstand loads, and here the advantage of the cores is clear and obvious.
The Cinebench rendering test also comes into the picture when it comes to such a processor:
It is clear to all of us, and Intel, that such a processor is not going to be used for editing content, and that is expressed in relatively low parallel performance. Specifying an 445 for a CPU in Cinebench R15 will be parallel to the cores that we met at the beginning of the decade i5 2400 for example. The performance of the single core on the other hand? As expected, are very high and stand in the line of processors others. 4.2 GHz is not a low working frequency, after all.
The power consumption data does not surprise us. Processor such as 14 nm from Contains a heat envelope of only 60 watts, and it also contains a fairly heavy graphics core in the form of HD 630. Without her, if Was able to declare a brown envelope, apparently it was also lower than 45 watts. Even with the hungry 780 GTX hunger, the test system did not exceed the Watts 310 while playing.
Tags
Back to top button
Close
Close
