The veteran hardware company is introducing a new line of fans to the home market, based on Magnetic Levitation technology
Company Corsair Introduces its latest innovation - fans based on "magnetic levitation" technology (Maglev).
Magnetic levitation means the use of magnetic deferral force to fix any metallic object without touching it. The most common use of technology is in magnetic trains, but it also has many advantages in hardware, such as minimizing the friction between the blades of a computer fan and the rotor.
Fans based on technology tend to be quieter even when the rate of revolutions per minute increases, and extend life in front of standard fans. It should be noted that the use of Maglev technology for cooling solutions is nothing new, but Corsair It is among the first companies to offer solutions based on it to home market users. The company also claims that its fans are "uniquely designed" because they have rubber sides.
The new fan series Launched yesterday And includes a number of models that are divided into the ML and ML PRO sub-series. The advanced model, the ML120, reaches up to 2400 rpm and pushes an air volume of 75 CFM. The main disadvantage of the new fans, as of today, is their high price tag. In the United States you will have to part with $ 35 just to get your hands on a pair of ML120 fans Nevertheless, this is the first swallow that may herald the entry trend of Maglev fans for the home user.
