• Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Recommended computers
  • Trade-Zone
  • Coupons and promotions
HWzone
  • Featured articles
  • Reviews
  • Guides
  • Technical Support
No results
View all results
HWzone
Main Computers
Review: Memories Corsair Vengeance Pro DDR4
By Lior Matityahu
28/08/2018
We took a look at what claims to be the most advanced RGB product in the world of dynamic memory - Corsair's Vengeance Pro, in the standard DDR4 of course. Is there a justification for price?
LED lights are slowly becoming the most common component in a modern gaming machine. You can not avoid them when you talk about advanced hardware today. Motherboards, Enclosures And surgeons have contracted this disease. There are several ways to do today RGB. Some choose a slightly more elegant and modest angle while others go for the brightest lights there are.
Today's review was found זיכרון Built and specially renovated for an experience RGB Perfect. How good is it really? You'll know later. Now, it's time to get to know the basics of the product
Corsair Vengeance Pro RGB
This is how the package looks. Specifically, we received the four-channel kit for top end systems such as Intel's X299 and X399 AMD. The price of these memories now stands at about 340 USD or NIS 1600 in private imports.
This is a pretty good price, since similar kits do not contain RGB Will usually cost about NIS 200 less.
The technical specification of this memory kit is:
  • Memory Type: DDR4
  • Memory Speed: 2666Mhz
  • Timings: CL16-18-18-35
  • Stress Action: 1.2V
  • volume: 4X8GB (32GB total)
The height of the memory is higher than normal, so you should pay attention to the compatibility of the curds. Aircircles such as Noctua D15 will fit as well as any kit Cooling Standard water.
This is how the upper part of the memory looks when there is a piece of frosted plastic over theRGB. This is a trend that I like very much because it comes out with a feeling of screen on memory and there is not too bright light due to the reduction of direct power.
This memory, of course, contains a heat sink made of painted aluminum alloy. Although the F-DDR4 Printed on only one side of the printed board, for convenience there is a body Cooling Which spans both sides of memory. The chips themselves are made סמסונג And are considered to be of the highest quality.
Control software - Corsair iCUE
This is the software for controlling all accessories Corsair Such as keyboards, mice, headphones and even Enclosures. The iCUE enables full synchronization and real-time preview of effects.
During the period I did not notice anything unusual. There is no excessive use of resources and software responses for very rapid changes. As a bonus the software also gives details like the temperature of the components.
Adjusting and setting up the memory lights is done very clearly and simply. There is a complete visualization of the location and color of the sticks in the system. Choosing an effect will instantly kill him. The range of effects is quite impressive and in fact allows Vengeance Pro memory RGB Perform visualization that does not exist in many products at all:
The animation, the intensity of the light and the amount of light in these memories is something we have never seen before. The engineering and thought she has invested are evident Corsair In these memories and the effects that accompany it. Of course for a perfect experience it is recommended to use all the available memory interfaces on the motherboard but given the memory prices today this is not an easy request at all. There is also performance of course.
Performance testing and overclocking
The memory test system includes the following components:
  • Processor: Core i9 7900X 10-Core
  • Motherboard: ASUS Premium X299-A
  • Graphics Card: NVIDIA GeForce GTX 1080 8GB
מבחן זיכרון A fast 2666Mhz speed on the test system results in a continuous reading speed of close to 70GB per second and writing 64GB per second. The timing of the initial access between the processor and the memory sticks is slightly higher. All these results correspond to the technical characteristics. What do you think we'll try to improve?
With the tools that Aida64 software gives us and bios settings adjustment, these are the overclocking results we came up with with memory. The goal is mainly to shorten the access time to memory a bit and if it is possible to pick up the reading speeds the writing and copying - why not.
The final memory frequency in what we call "conventional overclocking" has been raised to 3000Mhz instead of 2666Mhz. The timings were slightly released to CL17-18-18-39. The memory operating voltage has been increased from 1.2V to 1.35V which is still within the safe and normal range.
The read speed was improved by 11.5%, the write speed was improved by 12.3%, and the copy speed within the memory was improved by 10.6%. The access speed to memory has also dropped from 81.3 nanoseconds to nano-75.3. Not bad, not bad at all. With an ambient temperature of 27 ° C, the memory sticks did not pass the 45 line during the test. A very respectable result.
Summary
In this memory I had the right to use the last month for testing purposes. There is no doubt that,Corsair Raise the bar for everyone when it comes to the mirror זיכרון And how to control these bulbs. What's amazing is that this whole story is not as expensive as it might seem. The premium to 4 sticks is very modest and anyone who builds a computer with a particular look can add above and perfect the character of the computer.
Obviously, this is not a memory for every purchaser. When a budget is on the table, these dollars, which make up a small fraction of the total memory budget, can go to another important component rather than the LED lamps.
The iCUE software has evolved for many years until it reached its stable state today, simply because Corsair Is one of the most original in the field of control over hardware components. This software is now the most advanced and convenient for controlling light bulbs of hardware components. She does not feel like the quick work of a programmer who has just been told that a new product is about to be launched, and that you have to launch a supporting program, because I've seen them too.
Editor's choice and best design
Corsair Vengeance Pro RGB DDR4
The choice of prizes is easy. There is good and excellent, and when you combine a worthy price, amazing construction quality and stable and easy to use software come to a product like the Vengeance Pro RGB. These are among the memoirs ofDDR4 Most recommended for system builders who want a computer with a character. They will steal the play by virtue of advanced and unique control of the light bulbs in the memory sticks.
is also Overclocking there is. While the same 3000Mhz set is often available in some operations, the 2666Mhz set achieves overproduction results that can save a few tens of dollars effortlessly.
Tags: DDR4Corsair
Related promotions:
On the same subject news
Separate promises, separate reality: GeForce RTX 3060 lands with double and triple prices than recommended
Computers
05/03/2021
The Intermediate Card with protections against ambitious Ethereum reactors is designed to try and produce the severe shortages and exorbitant prices in the market - but right now reality paints us a completely different picture
קרא עוד
Get to know the computer that costs more than NIS 12,000 - without a dedicated video card
Computers
04/03/2021
The VAIO brand parted ways with Sony and became independent a few years ago, but it seems that the demonstrable disconnect between what is beautiful and elegant and what makes sense and pays off is still alive and kicking.
קרא עוד
Show more
  • Most popular
  • The most talked about
  • the newest
Starting from NIS 3,000, with a fast charger in the package? Xiaomi Mi 11 is ready for a worldwide attack
10/02/2021
Selfie screen and huge bulge for the cameras: Xiaomi Mi 11 Ultra
19/02/2021
Last day: a free double treat from Epic Games Store
10/02/2021
Console structure, PC games library: The computer that garnered NIS 8.5 million in crowd funding
07/02/2021
Intel announces that there will be no support for Rocket Lake processors for the H410 and B460 - the reasons here
10/02/2021
Three free games in one day: Take advantage of Epic Games Store's great deals
18/02/2021
The next front of the deficiencies? Digital coin miners are moving to laptops
First attempt at some order: NVIDIA artificially limits digital coin mining on GeForce RTX 3060
Tiger Eye: Tiger Lake performance on laptops in-depth testing
Packages, promotions and free to try or forever: lots of gaming deals for the new week
07/03/2021
Rain of titles: Sony and Microsoft's free games for March 2021
06/03/2021
05/03/2021
04/03/2021
Another important improvement to the collection: Galaxy A52 5G will offer official protection from water and dust
02/03/2021
The mobile that does it all - GIGABYTE AERO 15 XC computer with RTX 3070 in review
01/03/2021
HWzone is the oldest computer and technology site in Israel, which has been used for many years as a home for lovers of technology, computers and gadgets.
Wise consumers who like to be on the digital front - helping computers understand people since 2001.
  • about the site
  • Contact Us
  • Advertise with us
  • Terms of Use and Privacy Policy
No results
View all results
  • Computers
  • Gadgets
  • Gaming
  • Technology
  • Forums
  • Trade-Zone
