Another model, the same monstrous advantages: Xiaomi Redmi 8 viewed online • HWzone
GadgetsSmartphones
Another model, the same monstrous advantages: Xiaomi Redmi 8 observed on the network
Original article: Enthusiastic about the Redmi 8A but need more volume memories? There is a solution for you too
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
The Redmi 8A Fresh is one of the most exciting models ever to be priced at less than $ 100, but 32GB storage space may certainly be considered too small for any device As for the late 2019 - which explains why the Chinese manufacturer is also preparing the standard and improved Redmi 8.
The other new model appeared in the Chinese telecom operator's databases, and looks very much like the Redmi 8A with an 6.22 X-inch IPS screen at a modest 1,520 × 720 pixel resolution - though it contains a dual back-up array with a 12 main megapixel unit (Probably the same as the Redmi 8A, based on Sony's IMX363 sensor) and a secondary megapixel 2 unit that will probably be used as a depth sensor to create a bokeh effect.
The official price offered for the device, 1,600 RMB, is undoubtedly incorrect in being higher than 2 than that of the Redmi 8A - so it is best to treat all the technical data alongside it with some skepticism for now
The internal chip will probably be the The octagonal 439, as in the Redmi 8A, but with an enhanced 4GB dynamic memory and dual 64GB internal storage, with the option of further expansion with up to Terabyte microSD cards. Significant improvement over last week's releases - though we will keep our fingers crossed for a model with 128GB of storage (and maybe 6GB of As a bonus) for those who need it.
Redmi 8 has also been documented at the Chinese TENAA Agency - with a recent up-to-date design and approval for the dual rear camera Built-in non-existent in Redmi 8A
The best news is that the massive 5,000mAh capacity battery, with fast 18 watts charging based on connector Type-C, you will also be present on the Redmi 8 - so the biggest advantage of the Redmi 8A will be maintained.
We don't know yet when the Redmi 8 will be launched or how much it will cost - but we promise to keep you posted and updated when we find out!
updating: There is a deadline - the Redmi 8 will launch in India on 9 in October, probably with versions in some storage volumes and some volumes The most interesting of all is the top one, with 64GB for storage.
You can start the price guessing process
Tags
Leave a Reply
Back to top button
Close
Close
