A small upgrade or a big upgrade? Redmi Note 8 and Redmi Note 8 Pro arrived • HWzone
GadgetsSmartphones
A small upgrade or a big upgrade? Redmi Note 8 and Redmi Note 8 Pro have arrived
The new pair of smartphones There is a continuing tradition of exciting value for money
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
The pair of Redmi Note 8 models have been officially introduced to the Chinese market, with no doubt that a broader international launch will be coming soon - and it's a good time to decide which of the two is the one that is the shortest for you, if ever.
The big and senior Redmi Note 8 Pro of the pair will provide an 6.53-inch IPS screen with 2,340 × 1,080 pixels resolution and with Gorilla Glass 5 glass cladding both front and back, Helio G90T's Dedicated to gaming enthusiasts with a pair of advanced Cortex A76 cores at 2GHz frequency, six Cortex A55 cores up to 2.05GHz, and a Mali G76MC4 graphics core up to 800MHz frequency with an 4,500mAh Quick Charger 18mAh battery.
Two different models - each one is very lucrative at its level
The updated design will offer 6GB or 8GB dual-channel LPDDR4X dual-channel consumers, plus 64GB or 128GB internal storage that can be further upgraded via microSD cards, NFC is first built into the Redmi Note family, dual channel Wi-Fi 802.11ac connectivity, Bluetooth 5.0 connectivity, system Pie with MIUI 10 interface, rear built-in fingerprint scanner, infrared transmitter, 3.5 millimeter slot for headphones, basic (but formal) water and dust protection, Stereo, 20 megapixel selfie camera in a small 'drop' center and highlight area - square rear photo array with new main 64 megapixel unit, wide-angle 8 megapixel unit and XUM XX photography Last and favorite megapixel to use as a depth sensor.
The Note 8 Pro is undoubtedly a leap forward with a photo sensor at the onset, extra , Extra battery capacity and more
The standard Redmi Note 8 looks like a more modest upgrade of the various Redmi Note 7 models, both in terms of appearance and hardware. It will offer an 6.39-inch IPS screen and 2,340 × 1,080 pixel resolution similar to the previous generation, and will continue collaboration with Qualcomm within The octagonal Snapdragon 665 will not necessarily add Compared to the Note 7 Pro, but should be more efficient and economical thanks to its upgraded production process.
The Note 8 model can see a minor update for the Redmi Note 7 models for maintaining a similar overall design, similar performance and capacity Similar to the previous generation
The Note 8 will provide dynamic 4GB or 6GB memory alongside 64GB or 128GB storage and expandable microSD slot, stereo speakers, rear built-in fingerprint scanner, infrared transmitter, 802.11ac dual-channel Wi-Fi connectivity, modern Bluetooth connectivity, Pie with MIUI 10, 13 megapixel selfie camera in a minimum, 4,000mAh battery with 18 watt recharge - and a square rear camera that has an 48 megapixel sensor instead of an 64 megapixel sensor and three secondary sensors Note 8 Pro.
Home chip selection Won't you scare off potential buyers? We'll see
The prices, as always at Xiaomi, are very exciting - the company maintains a basic 1,000 RMB or 140 dollar value for the Redmi Note 8 model with 64GB storage and 4GB of dynamic memory, and offers the leading model of the device in China with 128GB storage -6GB's For 1,400 yuan, or $ 196 value. The base price of the intriguing Redmi Note 8 Pro with 6GB's And 64GB for storage will also stand at 1,400 yuan, while the leading Pro model with 8GB of LPDDR4X and 128GB of Will cost in the domestic market of the manufacturer 1,800 RMB, or 252 USD.
Each of the models will be offered in three different shades - and prices will be great as per the brand's tradition
Reason for partying for consumers or not? Feel free to discuss this with everyone in the comments.
Tags
Back to top button
Close
Close
