You have to see to believe: XumiX's technology will charge batteries in HNzone minutes
GadgetsSmartphonesTabletsTechnologyFeatured articles
You have to see to believe: XumiX's technology will charge batteries in 17 for minutes
The Chinese company ignites the imagination with the loading of a futuristic FT 100 that can fill 4,000mAh capacity at high speed 3 from everything we have met to date
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
We have to admit that Xiaomi has a problem: it has set itself a very high standard for my life It is precisely in its budget Redmi devices, with the generous capacity of 4,000mAh in most models - that puts in relatively third light its Mi family luxury products, which usually rely on more modest capacity batteries to maintain optimum compact dimensions.
To overcome the relative disadvantage, we have seen the Chinese manufacturer support 27 watt fast charging for the current year's products - though not at all sure it is enough to handle some of the parallel manufacturers, which also have capacity on their devices Large and especially fast loading. Nevertheless, it seems that it is not worthwhile to have my time in the meantime - a new video reveals to us Revolutionary that may place it as a leader in the field of batteries in the near future.
Super Charge Turbo is a strange branding, we must admit - but the technology behind it is special and serious
Brief documentation on the company's official page shows loading technology Future with maximum power of no less than 100 watts - comparing head to head with Super VOOC technology of the company Which is considered to be the most advanced and fastest today with a maximum power supply of 50 watts.
The end result is amazing, as expected - the 4,000mAh battery reaches more than 40 charging percentage in just five minutes, to 75 charging percentage in about ten minutes and full and full capacity in just 17 minutes, compared to the 31 "long" minutes required for the equivalent technology to bring an 3,700 battery For full capacity.
Oppo uses a pair Internals that charge up to 25 watts each at the same time to reach its impressive final figure - may it be possible for Shiumi to use a larger number of cells , Or are there any exotic materials that replace lithium-ion and support increased currents? As of now we can only guess
The video was published without further information, so we do not know when we may see this development in real devices in the stores, or whether it is a prototype of a practical prototype or just a concept video designed to illustrate something that is currently only in the laboratory exam. However, it is hard not to be impressed or even moved by the thought that soon five or ten minutes a day will be enough to ensure my life For an entire day, as an alternative to the one hour or even two hour loads that were common until recently in almost all models.
Will the documentation from an international organization spur Oppo, the And other players at the forefront of batteries to reveal their promising future developments? We will not object.
Tags
2 תגובות
  1. Reverse Guta (corporate orientation) Reverse….
    More interesting is how long the batteries last
    After charging, I'm afraid there are no loud news.
    So what - a built-in battery that costs quite a bit to replace in due course,
    And use time is not something for most models at a reasonable price.
    1. The battery holds according to its capacity, how old it is and how much you use your phone a day, not how fast it charges
Leave a Reply
Back to top button
Close
Close
