New in Israel: Smartphone less than 1,000 NIS with military rigidity
The new Q60 It is not the most powerful of all, but may be the most suitable for those who are looking for diverse photographic abilities and maximum physical durability at a modest price
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Parallel to the landing The LG G8s has a powerful processing chip The Israeli market has received another model of potential from the Korean manufacturer, this time to the boiling market, which does not require a four-digit payment for a quality and full (almost) uncompromising experience - the one in which names such as Yamumi, and also And Nokia.
The LG Q60 features an 6.26 IPS screen with 1,520 resolution × 720 pixels, Mediatek's Helio P22 with eight Corex A53 cores with a maximum 2GHz operating frequency and a built-in PowerVR GE8320 built-in graphics core, 3GB dynamic memory, 64GB internal storage that can be expanded on microSD cards, Pie with the interface UX 7 above, triangular backlit array with 16 main megapixel unit, 5 MP for wide angle viewing and 2 megapixel depth sensor In addition, a 13 megapixel camera with a small drop in the front and an 3,500mAh battery Which is supposed to deal respectably with the modest display panel.
The chip is basic in its capabilities and the microUSB connector inside is ancient - but a triangular, NFC and especially military toughness are helping to Stand out in the field anyway
The new smart device includes dual-channel 802.11ac connectivity, 5.0 Bluetooth connectivity, fingerprint fingerprint, 3.5 millimeter slot for headphones, DTS X Surround support for audio playback and a built-in NFC chip - but what distinguishes it most from other models At a cost of less than NIS 1,000, it is the official MIL-STD-810G standard for protection from blows, falls and shocks. If you have a tendency to eliminate At a fast pace it may be the best solution for you.
The device looks like a stepfather of the W - and we hope that it will nevertheless reach Israel due to the battery capacity it provides consumers
The Q60 is available in Israel in a blue or black shade with a recommended price of NIS 900, and the possibility to find it actually at a slightly lower cost of 875 shekels, and even less than NIS 750 for purchasers in Eilat without VAT. -Redmi Note 7 and A50 is very user-friendly. We'll probably soon find out.
A reasonable start-up cost - we hope to see a price war that will send it a little further downwards
