Samsung's new highlight: smartphone with 6,000mAh • HWzone battery
GadgetsSmartphones
Samsung's new record: smartphone with 6,000mAh battery
Original Article: Budget M20s are expected to offer consumers life Especially impressive when launched
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Galaxy M series of Made her world debut just a few months ago, but did so in style for us with a pair of models with With a capacity of no less than 5,000mAh - the largest one you can find with the major manufacturers in the market, all the more so at price tags that are less than 300 dollars.
The Galaxy M20 model is the only one in the family currently available for purchase in the country, thanks to the efforts of parallel importers, with the 6.3 × PLS screen at 2,340 × 1,080 pixels resolution, Exynos 7904 Octagonal, Memory Of 3GB, volume Internal 32GB and built-in 5,000mAh lithium-polymer battery as stated, with 15 watt charging.
The teaser with which this teaser was distributed declares that it is time for monstrous capacity, leaving little room to doubt the poet's intent
Enough for anyone? Turns out it's not that fresh teaser for a model Enhanced smartphone M20s clearly imply the use of an even more impressive 6,000mAh capacity. Answer to the upcoming Redmi 8? It's hard to tell, but we certainly appreciate the direction that should provide my life Certainly good value for all those who are willing to compromise on weight and thickness.
are you- M20 can be found in stores in the country starting at a price of only NIS 750 - a very interesting cost for the 5,000mAh battery
We do not have any additional technical data on the M20s model right now, so it is inevitable that a larger battery is designed for a larger display panel that will consume more energy - but we would be happy if You decide to upgrade other features of the model, such as the volume of memories it comes with, its photo arrays (with the main 13 megapixel camera and the 8 megapixel camera for selfie in M20), the fast charging capabilities and wireless connectivity that amounts to supporting only the 802.11n standard in the original version.
Also an improved version of the M30 (which also includes an 5,000mAh battery in it) is set to reach the Indian market in the coming month, with a major improvement in the photography sector that will replace a main 13 megapixel sensor with a modern 48 megapixel sensor. Will there also be an improvement in battery capacity? We will continue to monitor and update.
updating: First Photos of the Model The intended M30s came to the network, accompanied by strengthening assessments of using a main 48 megapixel photo sensor (within a larger than usual protrusion at the back of the product) as well as evaluations of using a formidable 6,000mAh battery in this case as well.
This is how the M30s when it is officially released - along with an explanation of the strange design aspect of the rear camera area, we hope
Model M30 is not yet available in the country and not at all sure that it will change sometime - but we would certainly be happy if the M30s land in the Holy Land in a while.
2 Update: We now also have an estimate for the expected price of the The massive battery M30s and the latest Exynos 9610 chip - between 15,000 rupees and 20,000 rupees in the Indian market, depending on available volumes of memory, or 209 dollars to 279 dollars respectively in conversion to the currency we know a little more. Also the The standard M30 started out in the country at a cost of Rupees 15,000, so there seems to be a proper upgrade here without a jump in price (which is something we're always up for).
The M30s are approaching - but not to our local market for now
Tags
Back to top button
Close
Close
