Panasonic's slim and revolutionary electronic fan • HWzone
Technology
Panasonic's sleek and revolutionary electronic fan
The electronics manufacturer introduced a new electronic fan without blades, based on special technologies developed by the company
Fans without blades Existing The market has been a respectable number of years when they have become widespread around the world. Panasonic recently introduced its new electronic fan, which promises to bring new and highly efficient technologies to the next-generation fan market. The thin fan, or his exact name "F-S1X Slim Fan", Can easily slip into every corner of every room - when its innovative design is certainly inspiring to be noted.
The fan operates like any fan without blades, based on sucking air and increasing its flow in a certain direction. It should be noted, however, that Panasonic's fan is based on the principle of fluidics - making it more efficient when it comes to environmental airflow in one direction.
The F-S1X Slim Fan is in action. Soon in our living room?
In addition, Panasonic has also installed the V-''Nanoe" Which, thanks to which the fan is able to mix the air with water particles with electrostatic charge, making the air more moist and gives a sense of breeze and freshness.
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Panasonic also explains that the fan can be used in the winter months as it recycles the air in the room and is not designed to affect the temperature.
The weight of the fan is 4.2 and its height is a little less than a meter, when the manufacturer states that its power consumption is very low - from 3 watts to 14W for work in effort. For which no details have yet been revealed.
Tags
6 תגובות
  1. Suitable for dry climate
    Mixing water with air is an old technique that is suitable for areas with little moisture.
  2. The water dispersion is not suitable for the center of the country.
    On the coastal plain there are high humidity percentages as well, a fan that sprays water splashes not suitable for such an area.
  3. I read this stack of words and still couldn't figure out how it worked :(
    Anyone succeed?
  4. The same principle makes it possible to make another product
    Due to our inventions in Israel, but it will be good anyway, with a solar panel that always draws the air directly into a filter and with an electronic control system informs us when to take the filter to the sink for cleaning… This is how it cleans and cleans endlessly and cleans the house of dust!
    Although there are air purifiers, futuristic designed air purifiers and with solar panel it is new!
Leave a Reply
Back to top button
Close
Close
