DJI Inspire 1: A futuristic UAV shot with HWzone resolution
Technology
DJI Inspire 1: A futuristic UAV shot with super-resolution
The tool, considered a UAV for professional users, comes with spectacular photography capabilities, a futuristic structure and a price tag of "only" 2,899 dollars
Get updates from everyone in TelgramGet updates from us all at TelgramJoin the channel now
Drone Inspire 1
Tiny aircraft (or drones) are no longer a matter of the future. With widespread use of military, photography, The rescue, Shipments and more, used drones in many areas around the world. But a new drone company Is about to change one of the most common areas used in such aircraft - the field of photography.
The DJI Inspire 1 tool It is not a regular drone. With a unique aerodynamic structure with four profiles on each side, the Inspire 1 drone comes with a stabilized camera with maximum video capture capability of , In addition to removable feet for easy landing and a structure that is partly made of carbon fiber, to reduce weight and further strengthen the tool. After the Inspire 1 drone reaches its target in the air, pressing a button on the remote control will cause the drone to lift its upper part attached to its upside-down camera to allow the accompanying camera to get a snapshot of 360 degrees, which looks like what can only be described as an alien spacecraft Preparing for a transformation. In addition, the camera can be detached from the drone body for "future upgrades," according to the company's official video on the Inspire 1 tool.
Basic Data - Inspire 1
  • Weight: 2.935 pounds
  • Maximum speed: 22 meters per second (about 80 mph)
  • Maximum upload speed: 5 meters per second (18 mph)
  • Maximum drop speed: 4 meters per second (14.4 mph)
  • Maximum Flight Height: 4.5 miles
  • Maximum flight time: 18 minutes
  • Battery Capacity: 4,500 mAh
transformingbg-f01fd81d2191ea6f8c88761b935d84c1camera-f12d5ee8259aa0fc9b25918d659abkec8
One of the interesting technology the company developed for the Inspire 1 drone is the Optical Flow technology. With this technology, the drone is able to track its height from the floor with the use of position sensors at the bottom of the tool, which allows Inspire 1 to stabilize itself inside buildings even without information From service any. Stabilized and highly accurate photographs could not be realized without this special technology developed by the company, making the Inspire 1 a spectacular photocopying machine.
The video that the drone is filming can be viewed directly on the special remote that came with the Inspire 1, which includes a screen and viewing range of over a mile at 720p resolution. With the option to connect the drone to a supporting device with the company's app, all shooting modes can be controlled Convenient and intuitive in real time and easy. For even more professional use you can connect with two signs to the Inspire 1 drone for separate flight and photography control.
camera
sensor: "Sony EXMOR 1 / 2.3 (with f / 2.8 lens)
Maximum photo resolution: 12.4 megapixels (maximum image size of 3,000 × 4,000), with the option of bursting at 3, 5 or 7 For a second
ISO range: Between 100 and 6,400
Field of view: 94 °
Video shooting: In 24, 25, or 30 frames per second,
1080p on 24, 25, 30, 48, 50, or 60 frames per second
And 720p in 24, 25, 30, 48, 50, or 60 frames per second
s5bg-362177720cc52cf8ae2640cbf4271cf1
full-app03-444ed67479a77b3835db6ba9a08b140d full-app02-f637b328b4bfaa7f535ffb6229e39c65 full-app01-09e90c09d2b8372b27a233b3b847b729
Pictures from the dedicated Inspire 1 drone app for the iPad
But with a high price tag (2,899 dollars [about NIS 11,200] per drone and one sign and 3,400 dollars [about NIS 13,100] per drone and two signs), the JDI Inspire 1 will remain in the use of professionals for the most part. We hope to see widespread use of the capabilities of JDI's new drone, but with the amazing final results taken from the Inspire 1 tool, you can clearly see that this is the new generation of photo drones.
Tags
3 תגובות
  1. You can do that with a lot of things
    This mile-long range can sit you in a distant place and travel with it in the city to rise to the top floors of luxury towers and get a pepperoni that will return your investment: |
    Or maybe he'll put you in jail.
  2. First - not that expensive. You haven't seen how much Yel is asking for much less.
    What's up - 18 minutes activity time? This drastically reduces the options.
  3. looltv DJI official importer in the country.
    Inspire 1 on the TV booth since the beginning of January.
    09:7660128
    0546669860
    A chicken coop
Leave a Reply
Back to top button
Close
Close
